HOTaljaard
The arm was at the end of the record, and I wanted to return it when I kind of sweep at it and it ended up dropping on the record. Turntable is a ClearAudio concept.
On inspection the needle doesn’t seem bent. The stylus tip still traces the arc protractor the same as before. Viewing from the side the tracking angle looks the same as before.
So, there shouldn’t be a problem, right?
Just to be sure I played Kerkorrel's Hillbrow (last track Side 1 of the Eet Kreef album). This song shows sibilance on my Thorens and Marantz but plays largely clean on the ClearAudio. Hence the reason why the AT-VM95ML cart/ClearAudio has been such a winning combination for me.
So now I’m hearing more sibilance on the Hillbrow track I think... All in the mind? Or did something change after my mishap..?
