For those with Wiim’s into DAC’s any suggestions
JoziNic
Well-known member
Jul 9, 2023
255
South Africa
Hi all, I have posed the below to the wiim forums also, and submitted a ticket but hoping perhaps someone here might be able to make a suggestion:
I am a recent owner of Wiim pro plus, and also a new to me DAC (TeddyPardo, TeddyDAC) And am playing off Roon, from a laptop in another room, using the wiim as an end point.
Playing the same 6 songs with the Wiim plugged directly into the amp via line out RCA & via coaxial out into the DAV
With the below issue:
Playing to the wiim - Line out directly to amp
Spotify: 320kbps, 16 bits, 44.1khz - plays fine
Roon:
44.1khz, 16 bits - gogo penguin plays fine
176.4khz, 24 bits - tsuyoshi Yamamoto- plays fine - source dsd64
44.1khz, 24bits - manu katche plays fine
88.2khz, 24bits - manu katche plays fine
96khz, 24 bits - manu katche plays fine
Into DAC
Roon:
176.4khz, 24 bits - tsuyoshi Yamamoto- shows playing on Roon, shows playing on wiim, no sound playing - source dsd64 - hi res light comes on - no sound playing
Here are pics of Roon & also wiim app showing they playing but no sound playing, the DAC shows hires music playing but no sound.
Any ideas welcome
Before I did the above test on the same 6 tracks, I was fiddling with the audio output settings for coaxial & Optical on the wiim app, I changed it to the maximum sample rate & bit depth (24/192) when asked to play the test sound I did and heard the sound then selected okay and then whenever I played a DSD file it does the above, shows as playing in both Roon & the wiim app, but there’s no sound (& the DAC says it’s playing hires”
If it helps I did also then try change back to different sample rate or bit depth and when asking to play the test sound I then didn’t hear any test sound at all
I looked up specs for the DAC, I do not see a mention of DSD anywhere, could it be your DAC does not decode DSD? Forgive me I am also new to the DSD format.
