HOTaljaard
Where can I order Spin Clean washer fluid?
E-Phiphany is sold out.
Mr Vinyl also doesn't have it on their website anymore.
A tad steep that...You can try at ImportItAll.
https://www.importitall.co.za/SpinC...eting&utm_medium=cpc&utm_campaign=remarketing
Apparently the proprietary Spin Clean fluid includes a flocculant.Couldn’t you just make your own? Distilled water, wetting agent, clean green, and alcohol? I doubt it’s highly proprietary
The interwebz says “distilled water and 99% alcohol in a 4:1 ratio and if you have it, a tiny amount of Ilfotol“
Simplest flocculant is plain alum powder that you can get from your pharmacy. I would not add it though. Might crystalize in the grooves if record is not properly driedApparently the proprietary Spin Clean fluid includes a flocculant.
One could add floculant to the above universal formula. Builders Warehouse sell HTH and Bluechem flocculant for use in swimming pools.
that IPA is Iso Propyl, and not Devils Peak IPA :-D10 percent IPA, 90 percent water (preferably distilled), a few drops of clean green. Should do the trick, then use distilled water afterwards. Rather that than buying a ridiculous premium thing.
The flocullant does sweet FA, the IPA and clean green provide the surfactant properties, you could add some wetting agent but frankly they are already there.
